blackstream Posted October 1, 2017 Share Posted October 1, 2017 (edited) Har läst på forum att man ska kunna fylla på däcken med balanssand genom att: Släppa ut luften ur däcket Tratt med balanssand mot ventilen Lyfta bilen så att däcket suger i sig sanden Det funkade hyfsat att hälla sanden genom en lös ventil jag hade liggande men inte när det skulle göras på riktigt. Nån som provat? Fail för mig iaf. Edited October 1, 2017 by blackstream 1 Link to comment Share on other sites More sharing options...
tuko Posted October 1, 2017 Share Posted October 1, 2017 When I had beadlock rims I used balancing beads. The easiest way I've read on the Land Rover forums and what I actually did is remove the tire, remove the air and break the bead of the tire on one side. Drop in the balancing beads and the refill with air. Literally 15 mins per tire. Todd. 1 Link to comment Share on other sites More sharing options...
blackstream Posted October 1, 2017 Author Share Posted October 1, 2017 (edited) Thx @tuko, seems like a solution. Should work without beadlock as well, bit hassle with tire bending though. These tires will go off in about a month so just trying this way of doing it for fun. Edited October 1, 2017 by blackstream Link to comment Share on other sites More sharing options...
Premium Member Lars 9k Posted June 16, 2019 Premium Member Share Posted June 16, 2019 On 10/1/2017 at 3:02 PM, blackstream said: Thx @tuko, seems like a solution. Should work without beadlock as well, bit hassle with tire bending though. These tires will go off in about a month so just trying this way of doing it for fun. Hur gick det med denna balansering @blackstream? Link to comment Share on other sites More sharing options...
blackstream Posted June 16, 2019 Author Share Posted June 16, 2019 11 hours ago, Lars 9k said: Hur gick det med denna balansering @blackstream? Gick fint. 1 Link to comment Share on other sites More sharing options...
Vikingstål Posted August 31, 2019 Share Posted August 31, 2019 Detta såg ju intressant ut. Används det istället för balanseringsvikter eller som komplement, samt hur beter sig själva sanden? Link to comment Share on other sites More sharing options...
haakonbs Posted September 8, 2019 Share Posted September 8, 2019 Jeg har bestilt det som kalles tire beads. Link to comment Share on other sites More sharing options...
Administrators Andreas.E Posted September 9, 2019 Administrators Share Posted September 9, 2019 On 31.8.2019 at 21.21, Vikingstål sa: Detta såg ju intressant ut. Används det istället för balanseringsvikter eller som komplement, samt hur beter sig själva sanden? Jag är också väldigt spänd på hur det går/gick! Link to comment Share on other sites More sharing options...
blackstream Posted September 9, 2019 Author Share Posted September 9, 2019 (edited) 2 hours ago, Andreas.E said: Jag är också väldigt spänd på hur det går/gick! Man använder istället för vikter och det funkar bra. Jag har använd dom här: http://www.easy-balance.se/sv/ Ser ut som kattsand, skulle inte förvåna mig om det är det, lite dyrare än kattsand bara. Man får kolla i tabell hur mycket man ska ha för sitt däck. Det man kanske ska tänka på är att man trycker i en del fukt i däcken när man luftar/fyller ute under granen och kattsanden suger ut sig fukten... klippt från easybalance: Balanseringspulvret är helt fri från giftiga ämnen och är en miljövänlig naturprodukt. Det tar endast sekunder att applicera EASYBALANCE under däckmonteringsprocessen och det krävs inga speciella ventilnålar. Balanseringspulvret absorberar fukt och kondens i däcket utan att klumpa och däcket balanseras under hela däckets livslängd. När däcken kasseras kan du till och med återanvända pulvret till dina nya däck! Edited September 9, 2019 by blackstream 1 Link to comment Share on other sites More sharing options...
iknutis Posted September 9, 2019 Share Posted September 9, 2019 Så da trenger du ikke lodd på felgene i det hele tatt? Og det funker like bra? 1 Link to comment Share on other sites More sharing options...
blackstream Posted September 9, 2019 Author Share Posted September 9, 2019 1 hour ago, iknutis said: Så da trenger du ikke lodd på felgene i det hele tatt? Og det funker like bra? Inge lodd och like bra, på ren Norska. 🙃 1 1 Link to comment Share on other sites More sharing options...
Vikingstål Posted September 14, 2019 Share Posted September 14, 2019 Jag har Googlat runt lite på ballanseringssand och ballanseringskulor och för det första så är det förvånansvärt billigt, beroende på märke då förmodligen. Men det är som sagt en aktiv ballansering som sköter sig själv och ändrar sig i däcket beroende på vart obalansen är. Jag tänker nog köpa dessa och ballansera om mina bfg ko2 under vintern då jag vet attt jag fortfarande har obalans sen dom monterades. "ATB Balanseringskulor virvlar runt i däcket från sitt viloläge, tills de lokaliserar området där obalans uppstår. Kulorna justerar sin position tills obalansen neutraliserats och är kvar i position tills fordonet stannar." Detta är taget ifrån märket ATB, Active Tire Balance. Hur pass små däck man kan ballansera med detta vet jag dock inte, och jag hittar heller ingen information om det. 1 Link to comment Share on other sites More sharing options...
blackstream Posted September 14, 2019 Author Share Posted September 14, 2019 8 hours ago, Vikingstål said: Hur pass små däck man kan ballansera med detta vet jag dock inte, och jag hittar heller ingen information om det. Det finns en kalkylator på easy balance hemsida som går ned till små personbilsdäck. 1 Link to comment Share on other sites More sharing options...
haakonbs Posted September 15, 2019 Share Posted September 15, 2019 Jeg hadde i ca 150 gr i mine dekk i dag. Fikk bare tatt reservedekk og bakhjul så ikke test kjørt. Var lettest å ta av hjulet og så skru ut ventilen Link to comment Share on other sites More sharing options...
