Jesper Løwe
Land Rover 110" Defender
On 4/10/2019 at 10:40 PM, Jesper Løwe said:
Opted for a second hand driveshaft with new universal joints today. Fitted but no test drive yet 🥵.
See now that was stupid...
Drove of for Poland friday before easter, with an untested prop shaft and within 2km it proved to be a major mistake anything over 80km/t made the car shake..
Trying to catch a ferry, we drove on, and it got better but not perfect.. 5 days on polish roads you dont feel it, but back home again its unbearable, removed the propshaft and now we are waiting for new Universal joints for the old prop shaft.. which was knackered before.. So the trip to Borås Jeepklub Softtrail is canceled :(  Maybe the parts will be here friday and ill get the time this weekend to change them.
  • Sad 2
Time´s flying and i´m trying to diagnose a "pling" sound i get from the transmission some times.  I cant replicated the the exact movement but i appears now and then on often after gear changes. i´ve been over propshafts, emergency brake, most of the bearings and nothing seems obvious, nor can i replicate the sound when the car is up in the air.
So i tend to  go on with other projects.
So the dual battery setup has startede. I got a ctek splitcharger last christmas, and the "pond" for the middle seat.
Test fitting the CTEk and a breaker.  I´m not sure its the way i want to go..  so its back to the drawing board.
Earlier this May there was a Outdoor fair close by and we went there to look for an extension to the MSR hiking tent. There was an interesting little detail to a rooftop tent at the fair.
The l shaped rails  with a cargo net attached.. This is was a great idea for boots and shoes when camping in the wet.
So now all i need is to find these sort of rails and cargonet from biltema.
In the workshop department, the truck had a new fanbelt, wich was a 15 minutes job
Out with old, and in with the new (no picture...)
In preparation for Overlanding Expo 2019 in august we where looking for a bike rack that could swing away from the truck, so we could carry bikes but still use the backdoor. My thule pivots down and leaves 50 cm to open the door..
I came really close to buying this dutch swing away tow ball carrier for fitting my existing bike rack, but 725€ was WAY over the budget..
Looking at multiple fiamma campervan bikeracks and "dreaming" multiple spare wheel carrying ideas.. 🤣
And found on used i wanted to buy online and weld some sort of mounting plate for...
I read the ad again until it dawned on me that it stated that it was for hanging ON the spare wheel, it was 7km from home and the bloke was negotiable for price..
Suddenly i was out the door, and came home with this "little" gadget
Bikes tested on and they clear the tent underside :-)
And clear the bodyside when the door is opening.
It needs new straps to fix it down, but thats fixable.
Next project is rear brakepads.. hopefully a quick job
And the a new sump gasket (that will be at my mates garage)
Brakepad change on a Defender should be like a walk in the park😊
Edited by Spoon
Har du prøvd å stramme boltene som holder den bakre mellomakselen til håndbrekkstrommelen?
Hvis de bare såvidt er løse vil trommelen bevege seg i det du girer og det oppstår ofte et pling eller ping 😉
On 5/24/2019 at 9:53 PM, Spoon said:
I toke the stroll in the park today 🤪
10min pr. wheel for the pads to be changed...BC9CDEC5-0D5E-420B-91D2-5B0338E53242.thumb.jpeg.06e60e791f6373d074c3c3e800638269.jpeg
And 10 min. A wheel to put on the 30mm spacers I bought second hand
Test drove it a little later an am I glad I brought the wheel wrench.. they needed a bit of a tightening after 10 km 😬
Blev ju snyggt med lite större ET till de breddarna!!
(Vilket skulle vara lägre ET) ☺️
Skrev ju fel ju .....
Joo..,, så är det ju, lite trött där eller bara otur när jag tänkte!!! 🙄
Men snyggt på bilen blev det åtminstone!!😉
Snyggt Jesper!
Som Lars skrev, ser mycket bra ut med lite bredd.
On 5/30/2019 at 10:50 AM, Wiberg said:
Snyggt Jesper!
Snyggt så det ud...
Men “Ride quality” var helt forfærdelig.. Det minde mest af alt som alle bøsninger var forsvundet fra bilen.
Spacers er nu fjernet igen og bilen kører “normalt”
Central låsen drillede på en af dørene..
Fik undersøgt og det gav mening
Fixed med ny ledning i lidt tykkere kvalitet
Hej Jesper. Har du fået den gennem syn med den forkofanger og winsch? Mvh Peter.
Ja, men med nummerpladen monteret i fairlead..
På en plade med 2 bolte igennem
On 6/14/2019 at 7:42 AM, Jesper Løwe said:
Snyggt så det ud...
When these wires short circuit you will discover that the same fuse also controls the "antitheft thing" (startsperre) so you will not be able to start your car. If I remember correctly you will get a flashing engine symbol on your dashboard. The wires LR have used are made from the cheapest possible plastic they could get, they have the same breaking strength as knäkkebröd😂
